front shock hub
Started by dazzle53, May 03, 2010, 07:16:04 PM
dazzle53
hi is it possible to seperate the front shocks from the hubs or do i have to replace the hole unit?
thanks
darren
the shock is an insert inside the strut/hub assembly.  You can't separate the strut from the hub carrier but the shock itself just slides out.
dazzle53
ok i see i dunno weather to change my shocks or buy cheap coilovers of german ebay. cheap uprated shock that i have found are £200 for all four corners or do i just buy the coilovers and sell my lowering springs  :-\ the coilovers are 500 euros
HELP PLEASE
well, coilovers if you want the height adjustment.  Personally, I'd rather spend less money on a decent quality set of shocks & springs than buy some cheap coilovers, cheap ones will have poor quality shocks and often poorly matched springs.
scotsjohn
Take a look at PPS website. They do coilovers on an exchange basis at £300 a set and offer a variety of spring rates.
dazzle53
loks like a good idea but what do i do about the rear can you get coilovers for the rear seperatly?
breadman
Yeah rear coilovers are available seperately, contact Phil J on here. He can supply most suspension related parts.
dazzle53
Weeman
PPS are also going to be selling polo specific rear coilovers too, so worth getting intoucj if you really want coilovers...
scotsjohn
I'm sure someone on the forum mentioned Mk1 Golf Gti rear coilovers kits fit Mk3 Polo, ask about.
yeah they do with the addition of a spacer on the bottom.
