[quote pid=2846 author=hayesey date=1217529130]ah right, sounds like you're already well on the way then.
GT inlet manifold has a larger bore than a g40 one so flows more air. Pulls harder in the top end but does sacrifice a tiny amount of bottom end torque, personally I much prefer he gt manifold. But I do like to rev my car.
BRM? do you mean removing the boost return pipe? Well there are two camps on this subject. I sit firmly on the side that cold air and spraying PTFE grease every now and then is much better than the standard hot air recirculating around and relying on oil breather scum to lube the charger apex seals. You don't have to spray PTFE every five mins, in fact that's a mistake some people make, putting too much in too often and it ends up with loads of it in the boost pipes.[/quote]
Off topic, but it would be nice somebody that knows the process how to lube the charger with PTFE spray (when running with no boost return pipe) ,to make a FAQ...
