Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
**UPDATE** New engine - starting...but tapping
« previous
next »
Pages:
1
2
Go Down
Author
Topic: **UPDATE** New engine - starting...but tapping (Read 5103 times)
Administrators
Housewives heart throb
Re: **UPDATE** New engine - not starting
Reply #15 on:
March 20, 2010, 06:21:33 pm »
pics might help mate!
ben_91
Reply #16 on:
March 20, 2010, 06:22:10 pm »
as Pete said above - I misread it
ben_91
Reply #17 on:
March 20, 2010, 06:22:53 pm »
it;s quite hidden but will do my best
Administrators
Reply #18 on:
March 20, 2010, 06:43:33 pm »
thats just a drain i think... from scuttle downt he back of the inlet
if its coming from there - would suggest yr heater matrix area has a leak - bleed screw open perhpas?
ben_91
Reply #19 on:
March 20, 2010, 06:47:21 pm »
yeah that makes sense because there was a puddle in there. I presumed it was because of the rain.
Will look and see why it's leaking there now!
Cheers Pete
ben_91
Reply #20 on:
March 21, 2010, 12:31:49 pm »
took it all apart and seems to be leaking from the matrix thing inside.
presume this is from me leaving it with only water in over the winter!?
Is there anyway of blocking it off so i can still use the car without the heating?
Ben
Puncharado
Back on the road in 2010! No, 2011! Maybe.
Reply #21 on:
March 21, 2010, 12:48:21 pm »
Just join the hoses together, or connect together both stub pipes in the engine bay.
I'm not sure if the coolant valve closes both sides, or how good it seals, but maybe it'll be ok if you leave the temperature set at full cold?
ben_91
Re: **UPDATE** New engine - starting...but tapping
Reply #22 on:
March 23, 2010, 12:44:47 pm »
Right - water leak is fixed now - only problem is it's tapping really loud!
No idea what it is as i put engine in without touching anything internal!
ideas?
Ben
Administrators
Reply #23 on:
March 23, 2010, 01:12:58 pm »
probably tappets as its been stood. Ensure oil is at right level and give it a good run out.
ben_91
Reply #24 on:
March 23, 2010, 01:42:04 pm »
ok will do
Traders
I know naathing..
Reply #25 on:
March 23, 2010, 03:58:19 pm »
Ben- engine was on a stand for about 18 months, so the tappets will have drained down. Usually takes a few hundred miles to recharge them properly.
Only other option is to do what Pete does and keep a set in your kitchen in a bucket of oil!
Pages:
1
2
Go Up
« previous
next »
Technical
