**UPDATE** New engine - starting...but tapping
Started by ben_91, March 14, 2010, 08:19:53 PM
ben_91
as Pete said above - I misread it  >:(  ::)
ben_91
thats just a drain i think...  from scuttle downt he back of the inlet
if its coming from there - would suggest yr heater matrix area has a leak - bleed screw open perhpas?
ben_91
yeah that makes sense because there was a puddle in there. I presumed it was because of the rain.
Will look and see why it's leaking there now!
Cheers Pete
ben_91
took it all apart and seems to be leaking from the matrix thing inside.
presume this is from me leaving it with only water in over the winter!?
Is there anyway of blocking it off so i can still use the car without the heating?
Ben
Puncharado
Just join the hoses together, or connect together both stub pipes in the engine bay.
I'm not sure if the coolant valve closes both sides, or how good it seals, but maybe it'll be ok if you leave the temperature set at full cold?
ben_91
Right - water leak is fixed now - only problem is it's tapping really loud!
No idea what it is as i put engine in without touching anything internal!
ideas?
Ben
probably tappets as its been stood.  Ensure oil is at right level and give it a good run out.
Ben- engine was on a stand for about 18 months, so the tappets will have drained down. Usually takes a few hundred miles to recharge them properly.
Only other option is to do what Pete does and keep a set in your kitchen in a bucket of oil!
