Bore size in MM, 1341cc
Started by Oily Fingers, March 01, 2010, 09:18:49 PM
Oily Fingers
Right just to confirm, as i plan to nip down to the local engine machine shop to ask about my rebore tomorow.  The 1341cc is 2mm bigger then standard g40 bore??  77mm bore?
joel
Alexiskayak_7
take the pistons in with you so they get it right.
Tommo
Yeah, the piston manufacturer should suppy you with what the clearances should be. Should be a pretty standard sorta thing though if not.
jez1272gt
As Tommo says the manufactures should provide a clearance. I know that Accralites tend to have a larger clearance than others.
Oily Fingers
koool,   cheers.
I havent ordered my pistons yet, waiting for next pay day!!!  should i wait and order them then get the rebore done to be safe or can i get away with rebore then order a set of 1341cc pistons???
no, get the pistons first.  Take them and the manufacturers spec sheet with you when you take the block in.
Oily Fingers
kool, cheers Hayesey!!!!  this mean i can spend some money on the Ducati this week!!!!!
joel
