pulling to the left on acceleration
Started by shaun_89, February 26, 2010, 08:18:47 PM
shaun_89
My g40 is pulling to the left when i put my foot down in any gear. Its straight when cruising and braking, any idea what this could be?
thanks
could be the ARB moving about, have a look at the front ARB mounts and see if the bits of the bar to either side of the rubber bushes have been rubbed clean.  If so then replace the bushes.
shaun_89
Ive got some new arb bushes today so will fit them and see if that helps.
anything else it could be so ill know if i still get the problem with new bushes
thanks
djtez
The track control arm bush.
get a big lever and work the arm about, it shouldn't have excess movement even with the lever.
sideshowwiggle
I've just got a G40 and have exactly the same problem but i'm lead to believe its just torque steering?
grayg40
mine also does this and my suspention is all new. torque steer as n/s/f wheel is your main drive wheel unless you have proper diff. but there could also be bushes gone.
