poor idle
Started by dannyb.G40, July 15, 2008, 05:23:32 PM
dannyb.G40
i know theres plenty about this on previous threads but not much about actual effects.
my batteries only kicking out about 11.5V with all the ancilliaries on at idle, and then only about 12.1V at idle with nothing on. Apparently its sposed to be churnin out around 13.0?
incidently at idle my car barely reaches 900rpm as if it keeps wanting to stall it the revs keep dropping. Will this be a result of the low voltage or something else (the lambda has just been replaced). will the alternator actually need replacing or refurbishing (my mate had his g60 refurbed and seems to be fine) or will it be fine.
(oh yeh the car is also slow to turn over is this also a result of poor voltage)
Any help much appreciated
Danny
sounds like a poor battery - or most probably a poor alternator... New or refurbed is best bet
supercharged spaniel
i think you have answered your own question really.  new alternator seems to be the next move i'd say and go from there. either way it needs sorting wether you like it or not by the sounds of it!  :D
DKnight
i know of a good alternator for sale, your lucky as they are a shit to find at times!
dannyb.G40
lol i thought as much, just wanted a bit of info from pro's i shall try and get it done later this week
cheers guys
dannyb.G40
Dk im interested wherebouts n how much!
dannyb.G40
bit of an update, had the altenator refurb'd and its pumpin out upwards of 14V now...cashback but havent fixed the idling problem so im gunna tek it to a garage n see wot he has 2 say.
oh and whoever thought putting the altenator below the charger inbetween the antiroll bar and intecooler needs shooting, 'twas a rite fiddly bastard!
grayg40
your idel control valve might be sticking. take the shaft end of a hammer to get down between the intake manifold and give it a tap to see if that works. It worked on mine, you don't want to have to buy a new one from VW cos its about £450 +Vat or there abouts. Someone told me you can take them to parts and give them a clean and grease and should be ok, but there a cunt to get at and okay if you want to take the risk puting it back together wrong.
Or
Try ajusting the screw on back of throttle body but take note of how much turns you turn it so you can put it back to the same place if it doesn't help.
dannyb.G40
thanks gray ill definately try the old "tap" method cant hurt giving that a go for free!
vwmk3jon
Mine was doing exactly the same. it would idle fine (probably whilst on choke) and then start to hunt, the revs dropping and rising to the point where it would stall.
Checked the Ohm reading on the Co2 pot and it was miles over the 575Ohm (was at 803!) so adjusted that and tweaked the screw on the back of the throttlebody and it seemed to do the business.
Now ive fixed my exhaust as it was leaking like a bitch from the manifold/downpipe gasket, its gone back to idiling rough again. I'm gonna check the timing as i have a feeling its slightly out!
and btw....How fookin much for a new ISV valve?????? I though inline fuel pumps were bad!
GSBellew
I got a new ISV a year ago, think it was more like €250, but I was told its now obsolete and that was supposedly the last one  ???
I had checked with my Bosch agent who told me they went out of production in 2002.
