Author Topic: fuel pump ! help  (Read 7181 times)
Offline projectg40
  • i need a bigger garage!!!
fuel pump ! help
« on: June 30, 2008, 11:34:10 pm »
:(  plz help i have a 1991 g40 to restore at last  :D  :D but i have no fuel at  the injector rail ? i have fuel  going ito the pump but nothing coming out the other  end (into the filter ) ican hear it doing somthing so the power is there ??? can someone advise do i need  a new pump ?if so where to get one ?? greatfull for any help cheers andy.....
« Last Edit: June 30, 2008, 11:36:15 pm by projectg40 »
Offline DKnight
Re: fuel pump ! help
« Reply #1 on: July 01, 2008, 08:19:13 am »
going off what you say it 99% has to be the pump
daft question is there fuel in the tank? how do you know the pump has fuel?
Offline giorgio
Re: Re: fuel pump ! help
« Reply #2 on: July 01, 2008, 12:23:08 pm »
I have a brand new uprated bosch fuel pump if you want to buy it. Although you best of trying another fuel pump as they are about £100
unplug the filter hose and see if there is petrol coming out of the pump. just start at the lifter pump until you no longer get fuel
Offline projectg40
Re: Re: Re: fuel pump ! help
« Reply #3 on: July 01, 2008, 04:37:50 pm »
[quote pid=2094 author=DKnight date=1214896753]going off what you say it 99% has to be the pump
daft question is there fuel in the tank? how do you know the pump has fuel?[/quote]
thanks for the reply ...  ill try to explain a bit better  :P a pipe comes from the fuel tank into a white box then out ov the re into a pipe going into the pump then out ov the pump into a pipe into the  filter then up to the injector rail i think ?? i have taken the pipe off the pump after the white box .when i turn the car on fuel is coming out ( into the pump  but when i take the pipe off the other side there is no fuel coming out but the pump is filling up / and yes there is about  a tenner in the tank.thaks  again  andy
Offline projectg40
Re: Re: Re: Re: fuel pump ! help
« Reply #4 on: July 01, 2008, 04:42:06 pm »
[quote pid=2098 author=giorgio date=1214911388]I have a brand new uprated bosch fuel pump if you want to buy it. Although you best of trying another fuel pump as they are about £100
unplug the filter hose and see if there is petrol coming out of the pump. just start at the lifter pump until you no longer get fuel[/quote]
cheers for the help iv sent  a p m could you let me no if you got it   (im a newbie learner on here ) :/  :/  :o
« Last Edit: July 01, 2008, 04:43:32 pm by projectg40 »
Offline DKnight
Re: Re: Re: Re: Re: fuel pump ! help
« Reply #5 on: July 01, 2008, 04:45:41 pm »
well going off what you say it has to be the pump...
Offline DKnight
Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #6 on: July 01, 2008, 04:46:15 pm »
whats an uprated pump aswell giorgio?
Offline giorgio
Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #7 on: July 01, 2008, 05:11:03 pm »
flows 135 ltr per hour opposed to the 70lph stock.
yoof did some calculations a while back
Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #8 on: July 01, 2008, 05:54:46 pm »
definitely the inline pump not working there.  The lift pump will be feeding fuel into the inlet of the inline pump which doesn't sound like it's doing anything.  Before you spend £100 on a new one, make sure it's getting 12v to it.
Offline projectg40
Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #9 on: July 01, 2008, 06:52:06 pm »
[quote pid=2113 author=giorgio date=1214928663]flows 135 ltr per hour opposed to the 70lph stock.
yoof did some calculations a while back[/quote]
will this pump work ok on a stock g40 ??
Offline giorgio
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #10 on: July 01, 2008, 07:32:39 pm »
[quote pid=2121 author=projectg40 date=1214934726][quote pid=2113 author=giorgio date=1214928663]flows 135 ltr per hour opposed to the 70lph stock.
will this pump work ok on a stock g40 ??[/quote]
yep, all you need to do is swap the end caps so you can plug in your wiring block.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #11 on: July 01, 2008, 07:55:10 pm »
it'll work but it's totally pointless and means you'll be pumping miles more fuel than you need to.
Offline projectg40
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #12 on: July 01, 2008, 07:56:39 pm »
[quote pid=2126 author=hayesey date=1214938510]it'll work but it's totally pointless and means you'll be pumping miles more fuel than you need to.[/quote]
Offline projectg40
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #13 on: July 01, 2008, 07:57:27 pm »
[quote pid=2127 author=projectg40 date=1214938599][quote pid=2126 author=hayesey date=1214938510]it'll work but it's totally pointless and means you'll be pumping miles more fuel than you need to.[/quote][/quote]
thanks
Offline giorgio
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: fuel pump ! help
« Reply #14 on: July 01, 2008, 08:28:09 pm »
[quote pid=2128 author=projectg40 date=1214938647][quote pid=2127 author=projectg40 date=1214938599][quote pid=2126 author=hayesey date=1214938510]it'll work but it's totally pointless and means you'll be pumping miles more fuel than you need to.[/quote][/quote]
thanks[/quote]
True, unless you are running some big power
