1272cc G-Lader Dyno Print Out
Started by Daryl, September 18, 2009, 08:55:36 PM
samg40
Yeah it was white, running 15" ATS cups when she had it.
grey G
If for example the power was over reading does that mean the torque will be too? By the same amount?
hardchargin40
Should be as power is a product of torque and rpm.
...unless the operator really messed something up inputting data before the run.
Do you know if he did a tranmission loss run down or just got the loss figures out of a book?
Power is torque x speed divided by 5252, so yes, they are related.
Only time you'll be able to differentiate between them is if you only apply a correction factor to one.
Correction factors are a calculation (If done to ISO standards) which rely on barometric pressure, relative humidity, air inlet temp and ambient air temp.
Your spec points towards the mid 150bhp area, which isn't to be sniffed at by any means  :)
