Final Problem! Hunting revs, hesitates when throttle is touched
Started by LeonL, September 14, 2009, 11:00:51 PM
LeonL
Removed standard air intake, air box, filter etc... today and replaced it with a Jabbasport kit. Took it for a wee drive and the car seems to be alot smoother. Didn't hesitate or anything, havn't checked to see if it still hunts revs yet.
Engine was warm/hot though so will wait till later when its stone cold and take for another drive to see if this problem has been eliminated.
Any ideas on why changing the induction for a Jabbasport one could have fixed the problem? Seems very strange!
Will confirm later if problem is solved
EDIT: PROBLEM STILL OCCURS
LeonL
Nah doubt it, looked pretty clean!
Edit: False alarm :( Problem is NOT fixed...Rah
jimbugalee
oh no Leon.  I've just spent months trying to sort this problem out.  Mine is now fine with new lamba probe :) Can't believe that's all it was but it may have been a combination of everything I tried.
LeonL
Hm...Unplugged my lamba today and not to sure if it made much difference. But i think it did, didnt seem to hunt revs as much. I'll just buy a new one and see if it sorts it :) Were did you purchase yours from and at what cost?
jimbugalee
Direct from VW ... think they're about £120 tho booooooooooooooo
Update on mine .... stalled again this morning with new lamba probe so still runs better with it completely off but it is better with a new one.  Think my mechanic is getting a tad annoyed now hehe
LeonL
Hmm...Unplugged mine and drove around for abit and the rev hunting defo improved, didnt seem to be 100% gone but is 99% better! Any ideas on if its safe to run the car without the probe? Does it cause any problems?
Also a faulty probe could be the cause of over fueling correct?
I'll be ordering a Bosch one from Eurocarparts today me thinks :)
jimbugalee
Anyone got any ideas why it would run 100% better with lamba probe off and with new one on it is improved but still hunts and stalls (mostly when cold)?
LeonL
Quote from: jimbugalee on October 11, 2009, 05:35:12 PM
Maybe its the actual wire/plug that connects the lamba sensor plug into the ECU (or whatever it goes to)
Shailan
when on idel does it cut out?
check the blue temp sensor, i changed mine recently it was all gunked! runs much better now
