Author Topic: G40 lader limitations.  (Read 7842 times)
Offline Andy
Re: G40 lader limitations.
« Reply #15 on: September 08, 2009, 09:23:31 am »
I burnt the final lot of seals on mine in the same way (pre-standalone) - I was doing 7100rpm at the time on a 65mm pulley, so roughly 13,280rpm charger speed. At least with a standalone you're optimising the amount of heat you can get away from that area - might not be a cure, but it certainly won't hurt.
Anyhow, the real point of this, is don't be a pussy and use a G60-lader instead. ;)
« Reply #16 on: September 08, 2009, 09:29:51 am »
Totally agree with andy...
however - surely if you are already making a bar of boost, there is some serious restriction in the system, get some of this in the engine (i.e. by more efficient throttle body/inlet) rather than backing even more boost up.
« Reply #17 on: September 08, 2009, 09:35:40 am »
Pete I think the issue is that these guys with 1473cc engines are finding that a g40 g-lader on a 65mm pulley is only producing 0.8bar boost at best.  Which in my opinion needs to be solved by putting a bigger blower on (be it a bigger supercharger or a suitable turbo) rather than trying to overwork the 40mm g-lader.
« Reply #18 on: September 08, 2009, 11:50:55 am »
still there is 0.8 bar backing up!! !if they want to keep the g40 and get more ponies, its time to look at other avenues me thinks.
Or whack a k04 on it, an eaton or g60 lol.
« Reply #19 on: September 08, 2009, 12:09:21 pm »
yes but it'll make more power with higher pressure in the cylinders.
Offline Varley
« Reply #20 on: September 08, 2009, 07:32:48 pm »
Cheers guys. Food for thought indeed.
I think G60 might be the best way to go. Well, a turbo is probably the best way but I'm a stubborn git!
I guess if I go with a smaller pulley on the '40 I'll end up with a dead charger that'll be worth f*ck all whereas if I set about the G60 route I can sell my '40 for sensible money as at the moment is fairly freshly full blended.
So what exactly would be involved?
One of these I guess?
http://www.g-laderseite.de/eshop/product_info.php?products_id=126
Would it mate up with my PSD intercooler without too much fuss?
What about toothies?
Where's the best place to source a G60 lader? Can you still get 'em new?
Thanks again!
Offline hardchargin40
  • Older, Wiser, Greyer.
    • The Roadster.net
« Reply #21 on: September 18, 2009, 09:56:30 am »
Could try JMR for a G60...
John Mitchell Racing on 07974 020031
Poss G-werks too if Darren's still going.
