Upgrading Brakes!!! novice questions
Started by cheddarcheese, September 06, 2009, 04:17:34 PM
cheddarcheese
why is there a vacuum hose that goes to the big black round thing with the master Cylinder in the middle? what happens if you don't have this blah blah blah?
andy
sinister polo
i think you will find that if it isnt connected your brake pedal will go solid after a few pumps!
Alexiskayak_7
Quote from: cheddarcheese on September 06, 2009, 04:17:34 PM
andy
Start your car, roll it (20 miles) then turn of your engine, give a few bumps on the pedal, you'll see that after 2-3 bumps you won't have brakes.
That black drum is a servo, it uses vaccum from the engine (inlet manifold) and it boosts up the pressure in the master cylinder, so you have effective braking...
it's a big diaphragm which uses vacuum pressure to help you press the brakes.
if you remove it (like a mk2 polo) the brakes will require you to press them harder but the benefit is that you get more feel through them.
