Gauges bar/psi
Started by cheddarcheese, August 27, 2009, 07:19:01 PM
cheddarcheese
I am about to buy some gauges for my G.
Oil Pressure gauge for my Stand alone charger oil kit
Air Fuel Ratio gauge
Volt meter gauge
Boost gauge
What reading should i get on my oil press gauge? bar or psi as its for my charger supply not engine?
and on my boost gauge should i get bar or psi?
i will also be getting oil press and oil temp latter on for the engine and a water temp guage to complete my collection.
bar and psi are just different scales for the same thing, 1 bar = 14.5 psi.  So it doesn't matter which you get.
You'll need a fuel pressure gauge for the charger oil system though as it doesn't run anywhere near as much pressure as the engine oil.
