Shopping list for gauge fitting - last question I promise!
Started by Alex, July 20, 2009, 08:32:23 PM
Alex
Last gauge-related questions, honest! Got it booked in for fitting a week Friday, but I want to make sure I've got everything I need first.
Obviously I will need a t-piece for the back of the head to fit the oil pressure sender.
Stack have supplied a sender with a 1/8 NPT thread, so one side will need to have the same. What's the thread on the standard sender? And it's the high pressure sender I need to tee into, right? Which one is this?
Same internal thread needed for the sump plug, going to talk to Think Auto about this tomorrow.
Wiring is the next thing I'm struggling with. Each gauge says it needs a 3AG 1 amp fuse. Do I need one for each gauge, or one for all three? Same for the 12V feed, can I tap all three into the same live feed? And the same illumination feed? Or is it worth getting some relays in there to avoid overloading anything.
the thread is m10x1mm, it doesn't matter which oil pressure sensor hole you tee into, they both get the same oil pressure in them.
I have the lights for mine tapped into the side light 12v supply from the headlight switch.
the ring round the fag lighter also has illumination
Alex
I've got my existing boost gauge wired to light up from the fag lighter illumination, might wire up the rest to do the same.
My AFRM is wired up to the windscreen wiper wiring as a switched live, can I run four gauges off this though?
Tommo
vwmk3jon
Alex (or anyone) - dont suppose anyone has a pic/link to where i can get the bits to plumb an oil pressure gauge in.
please thankyou
DMWG40
