Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Electrical
whiney fuel pump and i've changed it!!!!.. and lift pump...
« previous
next »
Pages: [
1
Go Down
Author
Topic: whiney fuel pump and i've changed it!!!!.. and lift pump... (Read 4859 times)
Administrators
Housewives heart throb
on:
June 27, 2009, 05:42:59 pm »
right, fuel pump started to whines like an RC car, so got a second hand one off dan barnes and swapped it. I also cleaned the filter on the intank pump.
It still whines!!!
what do people reckon it is??? fuel filter need changing?
Last Edit: June 28, 2009, 06:17:00 pm by PeteG40
scotsjohn
Probably the oldest G driver in the Universe.
Re: whiney fuel pump and i've changed it!!!!
Reply #1 on:
June 27, 2009, 06:12:09 pm »
A safe bet Pete, but what sort of mileage on it? My first filter change was at 165k on my old G.
Administrators
The CV joint killer
Reply #2 on:
June 27, 2009, 06:25:05 pm »
what about the lift pump? If that's worn out maybe the inline one is struggling
dannyb.G40
Reply #3 on:
June 27, 2009, 09:07:24 pm »
i changed the inline one and it didn't fix anything, turned out to be the lift pump as hayesey said
Administrators
Reply #4 on:
June 28, 2009, 11:31:20 am »
fuel filter has been replaced and looks quite new. I shall investigate the lift pump. It only does it on occasions, but embarrassing at the very least at traffic lights!
Administrators
Re: whiney fuel pump and i've changed it!!!!.. and lift pump...
Reply #5 on:
June 28, 2009, 06:17:54 pm »
right, changed lift pump and it still whines.
I'll change the filter tomorrow... but other than than, what can it be??? would a dodgy FPR cause the pump to overwork? it does seem to get warm when whiiiiiiiiiiiiiiiiiirrrrrrrrrrrrrrrrring and whining
scotsjohn
Reply #6 on:
June 28, 2009, 06:36:58 pm »
Any chance of a kink or crimp in the fuel line while doing other work? Return pipe blockage?
Administrators
Reply #7 on:
June 28, 2009, 09:33:24 pm »
i'll check connections in the engine bay... its weird as its only really bad stood/at idle.
1. Pipes in engine bay
2. fuel pressure reg
3. fuel filter
hopefully get to the bottom of it!
scotsjohn
Reply #8 on:
June 28, 2009, 09:42:47 pm »
At it's worst with least demand; starts to sound like the regulator.
Administrators
Reply #9 on:
June 29, 2009, 09:51:32 am »
i've got a few regs about... will check pipes and reg tonight..
fingers crossed will get to the bottom of this.
Administrators
Reply #10 on:
June 30, 2009, 06:14:49 pm »
pipes seem ok, regulator changed... now seems to behave... but not had a good test. Will test and report back.
pete
Dan
Reply #11 on:
June 30, 2009, 07:12:15 pm »
Interesting that regs do that. Not heard it happen before, but would make sense.
Administrators
Reply #12 on:
June 30, 2009, 07:38:12 pm »
only thing i can think is that the reg wasn't letting it return to the tank and therefore backing up and straining the pump
Pages: [
1
Go Up
« previous
next »
Technical
Electrical
