car wont start, no fuel getting to fuel rail SORTED NOW
Started by g40chris, May 17, 2009, 05:44:02 PM
g40chris
checked the car again earlier. im sure its the toad ai606 alarm/immob playing up, when you usually switch the alarm off the red flashing light turns green. instead its turning orange. plus when i switch the alarm off the water temp light flashes twice. i know these usually mean things but i aint got what the water temp light flashing twice then going off means.
i have looked into the toad ai606 on internet and it suggests by looking at other forums that other people have had this problem. just after the battery has run low
DKnight
fuel pumps cheap at VW?
if you see them as cheap then i strongly advise pay a mechanic/auto-electrician to look at the car since you clearly arent able to diagnose issues yourself
will save you causing yourself more problems
g40chris
my mate who is a vw mechanic is coming over this week to have a look at it. im sure that im going to need an auto electrician instead though. i will have to see what he says. just hope its nothing serious.
g40chris
i also have a mate auto electrician who is popping over 2moro night
g40chris
sorted now
was fuel pump relay
cheers for all the advice guys
