Author Topic: g40 turbo chip  (Read 9216 times)
Re: g40 turbo chip
« Reply #15 on: April 30, 2009, 11:01:14 am »
i'll take your advice :)
my friend is good in tdi remapping. we work together .. i send him files from cars in Bulgaria .. he take it to closest church and send it back to me :)
but i dont trust him for my car :D
is lambda sonda correct in his results.. i can test it with tool..
0.00v is very rich (~17,5:1) 1v is lean (~10.1:1)..
what i'll be efect from 4bar (3bar is mine now..) fpr ? i mean .. injector issues maybe ? i have 4bar fpr in garage somewhere..
turbo setup will looks more likely if i change turbo pipes with new ones... this weekend will change all pipes with aluminium
If you give me the flow rate of your injectors at 3bar I can do some rough maths to give you their effective flow rate at 4bar. Off the top of my head a 250cc injector goes to 320cc (ish).
10:1 is rich, 17:1 is lean ;)
Offline Vizor
Re: g40 turbo chip
« Reply #16 on: April 30, 2009, 11:12:22 am »
wrong.. sorry..
17.5 = piston with hole so you can't use it even for ashtray :D
there is a graphic for narrowband .. (0-1v)
http://www.nightrider.com/biketech/images/nbo2_output.jpg
hmm.. if i can write it somewhere i can make graphics
my injectors are stock .. g40 stock
Offline polo classic
Re: g40 turbo chip
« Reply #17 on: April 30, 2009, 11:40:13 am »
Opel Calibra used K16, not K14
Re: g40 turbo chip
« Reply #18 on: April 30, 2009, 11:59:08 am »
Quote
wrong.. sorry..
17.5 = piston with hole so you can't use it even for ashtray Cheesy
yes but that happens because the fuelling is lean so he isn't wrong.
Offline Vizor
Re: g40 turbo chip
« Reply #19 on: April 30, 2009, 12:01:12 pm »
yes but k16 wich is used opel in calibra turbo .. this is only petrol engine from kkk k16 list :) that exactly i mean
http://www.turboost.lt/eng/catalog.php?m=KKK&fam=K16
Offline Vizor
Re: g40 turbo chip
« Reply #20 on: April 30, 2009, 12:02:36 pm »
Quote
wrong.. sorry..
i mean .. MY wrong :) i know what
if air/fuel ratio is rich then we have internal detonation => woodpecked piston :D
Re: g40 turbo chip
« Reply #21 on: April 30, 2009, 12:26:22 pm »
Quote
haha, that's one way of putting it.   ;D
Re: g40 turbo chip
« Reply #22 on: May 04, 2009, 02:23:28 pm »
Yes, but just like the K16 used by Porsche, it is made from different material than the diesel versions.
Offline Vizor
Re: g40 turbo chip
« Reply #23 on: May 18, 2009, 11:16:29 am »
can i fit different than 3f camshaft :(
i can't find this cam in bg :(
i mean different than 030109101AF some from 030109101* group?
