Author Topic: converting to 1341?  (Read 11228 times)
Offline Andy
Re: converting to 1341?
« Reply #15 on: April 29, 2009, 06:31:52 pm »
standalone can manage the timing and fueling better than stock ecu.
Indeed, but you need to bin the dizzy and install a crank trigger wheel to take advantage of it - something I plan on doing eventually with Emerald. Until I do that, it's no more accurate than Digifant.
« Reply #16 on: April 29, 2009, 08:49:27 pm »
How'd you figure that?
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #17 on: April 29, 2009, 10:30:01 pm »
High boost on 9:1 is attainable, but Aquamist and BV head are pretty much essential. The critical part is getting a decent chip.
smooooooth - no link to the chips you're selling ;-)
It's true though, the map is the critical part in any highly modified G40 motor - otherwise you may as well stick on an R5 carb and drill random holes in the jets. Steve always used to say the same, and it still surprises me how many people will spend thousands on an engine and bolt-on bits, and then run it on a generic chip that has fuelling and ignition timing miles off what it needs to be. Robin's det-prone 1341cc (stock head, non-1341cc cam) made an extra 10bhp or so on the dyno with a few minor map tweaks - still needs more, but it proved the theory.
You run massive boost, you need the ignition timing and fuelling setup accordingly. That's the main reason I bought Emerald - so I could tweak the mapping easily myself. In the meantime I carried on messing about with Digifant and got my head round the map structure.
had a 1341cc cam but no BVH.
Will be using PPP soon to do some custom mapping
Offline lance
« Reply #18 on: April 29, 2009, 11:00:23 pm »
stock ecu as in shit map sensor and yea yoof yours is all different fair enough, drop the know it all attitude.
Offline Andy
« Reply #19 on: April 30, 2009, 08:07:50 am »
Digifant Pros and Cons
+ It's already on the car, so free!
+ Re-mappable with full control of fuel and ignition.
+ Can be mapped/tweaked to run a turbo or Eaton.
+ Darn site cheaper than a standalone system, no additional sensors required, wiring's already done etc.
+ Can be cheaply expanded to run switchable maps (circa £50).
+ Custom rev limits possible.
+ Generic 'base map' chips widely available cheaply.
- MAP sensor limits boost to 1 bar - but is easily changed for £50 or so.
- Limited number of places to remap.
- No electronic boost control - but aftermarket electronic boost controllers can fix this.
- Can't run crank trigger wheel and wasted spark for uber-accurate fuelling and ignition. (But a standalone will only be more accurate if you use the crank trigger wheel - if you stick with the paddle in the dizzy it's no better than Digifant).
Be good to add more if anyone can think of them.
It's ultimately cheaper to stick with Digifant if you're only going to get one or two remaps, even if you want switchable maps, a larger MAP sensor and end up buying an electronic boost controller - if you go standalone making the new loom and buying new sensors soon adds up if you're doing it properly.
On the other hand, going standalone can give you lots of new features (e.g. flat-shift, launch control) that Digifant doesn't have, and if you buy something like an Emerald the chances are you'll find somewhere localish that can map it.
Offline Glader Poison
« Reply #20 on: April 30, 2009, 08:59:09 am »
Well I'm following this thread with interest and I think it deserves a sticky topic just for itself because the importance of the subject...
G-reets,
Bruno
« Reply #21 on: April 30, 2009, 09:40:13 am »
calm down kiddywinks,  its all about the g40 love...
« Reply #22 on: April 30, 2009, 09:43:51 am »
lol- If you're willing to make a sweeping statement at least explain fully why you think it's shit. The stock digipants ECU is more than capable of running various different combinations of charger/turbo/capacity etc.
In the states you'll find alot of the budget drag boys use G60 Digifpants ECU set-ups, on 8v n/a, 16v n/a, 16vT etc etc because they have a good wealth of knowledge and the ability to calibrate the map to suit.
The answer isn't always to throw money at the problem...
Offline Fred
  • Fred
« Reply #23 on: April 30, 2009, 10:07:47 am »
So at somepoint the Vernia cam pulley comes into play then. LoL.
Glad i`m just having filter/exhaust mods then  :)
Fred.
« Reply #24 on: April 30, 2009, 10:09:36 am »
Fred.
 :D Soon, I Promise!
Offline lance
« Reply #25 on: April 30, 2009, 01:11:14 pm »
i never throw money at a problem we cant up here as there is only a couple of people around into performance cars, i got my dta for £300 and ill be fitting it so it wont cost much more that what you will have spent by the time you get a trigger wheel, if your going that route plus the electronic boost controll so i can mess about with having progressive boost maps and things like that, mainly ill be running standalone as ill be using a different throttle positon sonsor on my inlet i am making.
Offline LiamM45
« Reply #26 on: April 30, 2009, 01:20:07 pm »
I was looking at a very well known show car/track car on the VW scene yesterday.
It ran MOTEC management with 30+ sensors.
Out of those 30 sensors, either 4 or 6 were in use.
If he saved all his money and kept the VAG management, it would've still ran exactly the same with a re-map.
VW didn't spend all that money making an ECU for nothing!
There's a message in this post somewhere...  :P
« Reply #27 on: April 30, 2009, 02:10:28 pm »
Great, there's no need to see your arse just because I ask you to justify a sweeping statement. Good to see you're hoping to maximise the extra features of DTA, you thought about front/rear wheel speed sensors for a traction control system?
Offline lance
« Reply #28 on: April 30, 2009, 02:36:21 pm »
just tend to find alot of people in the (vag scene) are know it all internet keyboard warriors.
yea looked into it a little my mate has used an abs sensor setup on his nova but he can fit the cv's on his but i dont think there is any for an easy fit into a polo hub is their?
launch controll would be good so worth lookin into,
i am making a manifold with bike bodies built into it with pulsar plenium and parts, the ecu will run my injectors plus the bike bodie ones, i was also thinkin of trying to map my nitrus into the dta too.
« Reply #29 on: April 30, 2009, 03:42:16 pm »
I'm not your average keyboard warrior  ;)
A fair few VAG cars use wheel speed sensors, you'll have to make a bracket and work out a way of mounting the trigger wheel ring onto the hub, the rear it should be easy, not so sure about the front, could use an electronic drive off the gearbox speedo drive though.
Launch control can be worked off a maximum rate of acceleration too- so doesn't need wheel speed sensors per say. I.E if speed ramp rate is above Xrpm/s then cut ignition logic.
If you're using a pulsar plenum, why not use pulsar bodies too? I can see the advantage of staged injection, personally I'd use the pulsar stock injectors, and then mount 4 in the rear wall of the plenum and fire them stright into the trumpets- should give good power gains.
As for nitrous, depends how much you want to run, 25bhp hit you'd possibly get away with your normal map, depending on your a/f ratio aims on nitrous. After that a secondary map on DTA when the gas solenoids kick in would be advantegous. Check WON for their staged systems, if you're running staged injection they'd complement each other perfectly, possibly sack off the fuel solenoid and use the second bank of injectors for fuel enrichment.
Food for thought, sounds an interesting project though.
