Pipe missing?
Started by BrettG40, April 25, 2009, 07:59:26 PM
BrettG40
Hi guys,
just purchased a G40 today, well happy with it. Just a quick question though, the pipe that normally goes from top of charger in through rocker cover, out rocker cover and onto throttle body is non existent, a blanking plate is in place on the charger, and i have a slight oil leak which i presume is from a breather pipe that should be connected to the missing pipe, any ideas?
Thanks.
Brett
BrettG40
Can anybody help me out??
it's quite a common modification to remove the "boost return" pipe.  The oil leak sounds like whoever did it hasn't connected the breather pipe up to a catch tank which you have to do when removing the boost return pipe.
BrettG40
Oh ok, thanks for your reply, so the throttle body and rocker cover stay as they are with no pipe on them at all? Ok ill look into a catch tank, or purchase all the required pipes.
vwmk3jon
theres a catch tank on ebay at the moment.
