Author Topic: Running Issue  (Read 15537 times)
Offline supercharged spaniel
  • GRRRRRRR
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Running Issue
« Reply #15 on: March 06, 2008, 04:05:45 pm »
[quote pid=160 author=Dougy date=1204799888]Well got up this morning started driving to work did 1 mile and smelt petrol it was pissing out of the fuel pump
Note to self never use jubilee clips[/quote]
ive had jubilee clips on mine and theyve been fine... so far lol
Online PeteG40
sorry dougy, didnt reply to yr test... normal vag ones are single use.. get proper fuel pump clips if you can - far easier to work with!!!
Offline Dougy
Hello guys I'm back again and i'm proper puzzled now really need some help
Changed the fuel pump and suprise suprise it didn't change anything but strangly it made an even louder squeel than my previous one.
Now car still runs like shit, unplugged lamba and sounded like it was running better but made no difference to the running still slight drop in rev's above 2.5k.
Now apart from the above other obvious faults is terrible fuel consumption I'm getting around 35 miles to £10, car smells of fuel all the time running very rich and when you put your foot down there is just loads of smoke which I presume is the fuel.
Has anyone got any ideas cos i'm all out
Offline DKnight
hmm does seem strange, id try a different lambda probe first, maybe the probe makes it run shit, and with it off, it will over fuel so run shit?
it can only be so many things really, all which can be swapped!
if not probe then do the blue temp one...
Offline Dougy
Going to Rae's tonight
Hopefully get to the bottom of this
Will report back
Offline Dougy
Well went to Rae's last night and hooked it up to laptop to try and find the answer to this problem
Alternator = Fine
Lamba = Fine but sluggish
Timing = Fine
Dizzy = Fine
Battery = Fine
Fan = Was wired up backwards explains slight temp issue (just another problem caused by the person who did the conversion)
Blue temp sender = Fine
Knock Senor = Disconnected
So we could not pin point the exact problem
But it did narrows it down to a few things to check
Coil
ECU
Fuel
Anyone want to take bets on which one it will be??
or can think of anything else to check
« Last Edit: March 20, 2008, 09:34:57 am by Dougy »
my vote is on the ECU because that's what was making my car get the hump a while ago till I replaced it!
Offline Dougy
Well suprise suprise its not the ecu
Car is running very rich and my money is not on the injector rail
It has to be some problem with the fueling system
Any ideas guys
Online PeteG40
what chip does it have?
Offline Dougy
had a standard one on before then switched it with a Jabba one
Offline Dougy
Right this is starting to get right on my tits now
Only thing that it could be now is the Injector Rail or Intank Fuel Pump
Changed the fuel filter yesterday and made no difference
Could an injector rail cause this much trouble?
Online PeteG40
in tanks are £20 new...  i think i might have a fuel rail with injectors you can try if needs be
Offline Dougy
I have injector rail to try its the intank one I don't have which I want to try first as the pump other fuel pump is still making a noise suggesting that theres a block intank pump
