Author Topic: what size tyres for my new wheels  (Read 7017 times)
Offline g40chris
« on: March 11, 2009, 03:24:02 pm »
i got a set of schimiter gte wheels which i have been refurbing for the G40, i have also had them redrilled for vw fitment, need to get spigot rings made by mate next.
they are 14" in diameter but im not sure how to work out the offset or width, where to measure from and to...?
im wondering what size tyres i need to order so they dont foul the arches. the car is quite low on the front but rear end sticks up a bit. either 40mm or 60mm drop iirc on koni dampening adjustable suspension
Re: what size tyres for my new wheels
« Reply #1 on: March 11, 2009, 06:46:53 pm »
offset is usually stamped on the wheels somewhere, "ET" followed by some numbers.  It's not easily measurable.
Offline G-spot
« Reply #2 on: March 11, 2009, 08:13:08 pm »
This about somes it up,
the distance from the inner edge of the rim to the mounting face of wheel, minus the half the rim width(distance between bead seating area), if its negative then your already up against it with clearance.
If your on 14"s then I'd recommened 195/45 or 185/50(expensive if you can find some) though I'm sure 175/60 would be alright, but think the rolling diameter gets a bit large on that profile.
are they the slot mag style one's??
Offline g40chris
« Reply #3 on: March 11, 2009, 11:43:06 pm »
this is what they look like
i have 2 sets
Offline g40chris
« Reply #4 on: March 12, 2009, 12:04:01 am »
it says 6x5.5
cant find et anywhere on them
the wheels are made in uk by dunlop
the outside edge is chrome and the inside is a softer metal, like aluminium
if these are 5.5 inch wide then will the 195/45/14 fit them ok and where is best place for me to get them at a tidy price
Offline G-spot
« Reply #5 on: March 12, 2009, 02:18:18 pm »
known as the Dunlop Alloy which is a steel Alloy composite wheel, ooooh :o
Anyway, a bit of info on this link
http://www.sporting-reliants.com/wheel_guide.htm
plus this one too
http://www.kewengineering.co.uk/upgrades4mgs/Drivetrain/restoring_mg_bgt_v8_dunlop_rims.htm
« Last Edit: March 12, 2009, 02:20:21 pm by G-spot »
Offline G-spot
« Reply #6 on: March 12, 2009, 02:24:34 pm »
try AutoStop on Brackla industrial estate(Bridgend-not to far from you) the do Falken's ZE's in that size which is a good around tyre in my opinion, there not super soft so if your looking for bags of grip then there are better tyres out there.
Offline g40chris
« Reply #7 on: March 12, 2009, 06:25:55 pm »
awesome. nice refurb advice
i still need to work out the et, is it in mm from the mounting face
Offline breadman
« Reply #8 on: March 12, 2009, 08:26:36 pm »
If they're only 5 1/2" wide I wouldn't fit a 195 tyre. Even with a 45 aspect ratio they'd be a bit "loose" in terms of sidewall control.
5 1/2" x 14" isn't a good size wheel when it comes to tyre choice. 175/55 would be about the best fit I reckon.
Offline g40chris
« Reply #9 on: March 12, 2009, 08:40:38 pm »
i was worried about that with the width
Offline Dan
« Reply #10 on: March 13, 2009, 09:08:27 pm »
In all my days of polo's I never thought I would see someone put Reliant scimitar wheels on a G40
Offline g40chris
« Reply #11 on: March 13, 2009, 09:16:27 pm »
gotta be done
had the car 8 years so giving it a refresh with a few new bits. but had the idea of the schimitor wheels as i seen a set on wheel whores and got my thinking cap on, its not a very big cap mind you.
what you guys think, good idea or bad...?
well i got 2 sets now
Offline Dan
« Reply #12 on: March 13, 2009, 09:22:43 pm »
fair play, might as well try them as you have got them to the right PCD. See what they look like....
You can always change them  :P
Offline g40chris
« Reply #13 on: March 13, 2009, 11:04:39 pm »
if they work out ok then i will do the other set the same and sell them
