Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Co pot readings
« previous
next »
Pages: [
1
Go Down
Author
Topic: Co pot readings (Read 3468 times)
G40Nik
Co pot readings
on:
May 30, 2019, 06:42:37 pm »
I did a reading check on my Co pot outerpins and meter read .835 is this high ?
sleag40
Poloist
Re: Co pot readings
Reply #1 on:
May 31, 2019, 06:20:43 am »
It doesn't matter what the reading is as long as the car runs correctly - if it passed the MOT emissions test I'd leave it alone. Mine is set at 2k+ due to bigger injectors.
G40Nik
Re: Co pot readings
Reply #2 on:
May 31, 2019, 06:41:34 am »
Ah ok i did read somewhere it could be between 600 and 850 on tuned motors if yours is more then should be ok.
What injectors are you running?
Mine is on standard injectors was told i could go 315cc.
sleag40
Poloist
Re: Co pot readings
Reply #3 on:
June 01, 2019, 08:31:08 am »
My injectors are 310/315s - unnecessarily large, as G60 size would be fine. When the car was mapped, that was all they had in stock.
G40Nik
Re: Co pot readings
Reply #4 on:
June 01, 2019, 09:11:01 am »
Ah cool ok what sort of power you getting with your setup?
sleag40
Poloist
Re: Co pot readings
Reply #5 on:
June 01, 2019, 09:04:26 pm »
When last on the rollers in 2012, it produced 173 bhp @ 6050rpm. When mapped back in 2008 the original injectors were maxed out at an unsafe 160bhp - hence bigger ones were required.
G40Nik
Re: Co pot readings
Reply #6 on:
June 13, 2019, 08:00:34 pm »
Cool any idea who would do the mapping if I was to get the G60 injectors mine was originally custom mapped by PSD.
Pages: [
1
Go Up
« previous
next »
Technical
Co pot readings
