Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Still have a starting issue
« previous
next »
Pages:
1
2
Go Down
Author
Topic: Still have a starting issue (Read 6207 times)
GR40
Re: Still have a starting issue
Reply #15 on:
December 22, 2016, 02:17:23 pm »
What injectors are you using? It might be overfueling or it may be something electrical. Take the spark-plugs out and check them. I would start from there!
matthg40
Reply #16 on:
December 22, 2016, 02:27:42 pm »
G60 golf rally injectors.i put them on as I was running to much boost and not enough fuel at one point.checked plugs they are abit black but not herendous car could do with a service if I'm honest
GR40
Reply #17 on:
December 22, 2016, 07:57:14 pm »
I assume you did remap the ecu to use the G60 injectors. just dropping them in will let the car idle but will overfuel the hell out of it. Black plugs mean too much fuel or not enough spark.
kwijibo_coupe
Reply #18 on:
December 22, 2016, 10:56:34 pm »
If the ECU isn't seeing over 12v it will run like a bag of shit, they are quite picky like that.
It sounds like you have either a charging issue or the coil is failing. Possibly a combination of the two.
matthg40
Reply #19 on:
December 23, 2016, 11:03:51 am »
The car has been chipped with everything that has been added to the car performance wise I had it made for me at ppp years back.i think after Christmas I shall replace the alternator and coil as people seem to be suggesting they could well be the problem here
Pages:
1
2
Go Up
« previous
next »
Technical
