Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40
General Car Chat
Oil cooler position
« previous
next »
Pages: [
1
Go Down
Author
Topic: Oil cooler position (Read 2937 times)
physicsfool
Oil cooler position
on:
June 28, 2016, 08:39:04 pm »
Looking for optimum oil cooler position. It's a 13 row mocal one. Can't seem to fit it nicely behind the bumper bar.
Any hints?
josé
Re: Oil cooler position
Reply #1 on:
June 29, 2016, 08:37:14 pm »
If your going to put it there then I wouldn't bother fitting it unless you sit it a lot lower so that it catches air from the fog light opening, mine is fitted behind the grille next to the drivers headlight
I'll find a pic
kwijibo_coupe
Reply #2 on:
June 29, 2016, 11:07:22 pm »
Mine is the fitted on the passenger side and it is at 90 degrees compared to your one so it gets air flow from the fog light cutout.
physicsfool
Reply #3 on:
June 30, 2016, 01:24:32 pm »
Cheers for the suggestions. Struggling for space next to the headlight as i have a fmic and charger. Will try adjusting it through 90 degrees. haven't drilled any holes yet
kwijibo_coupe... does it keep the engine temp down? even when ragging it in that position?
josé
Reply #4 on:
July 01, 2016, 04:46:54 pm »
Yes it will do I had mine there originally, but moved to the grille because I didn't want the empty fog light hole in the bumper,
Mine is turbo so I will have more clearance next the headlight should of thought of that.
SamG40
Administrators
Take.... on.... me....
Reply #5 on:
July 03, 2016, 10:26:05 am »
Not sure if its the same size oil cooler but this is where mine was.
Pages: [
1
Go Up
« previous
next »
Club G40
General Car Chat
Oil cooler position
