Author Topic: New G40 Maps- In Stock!!  (Read 80893 times)
Re: New G40 Maps- In Stock!!
« Reply #60 on: November 01, 2010, 08:08:29 pm »
Don't jabbasport normally call that an R1?
Offline matthg40
« Reply #61 on: November 01, 2010, 08:41:57 pm »
yes mate i put that on  my original post pete asked what the r1 meant  ;D
« Reply #62 on: November 01, 2010, 09:08:07 pm »
You said R5 :)
Offline matthg40
« Reply #63 on: November 01, 2010, 09:25:30 pm »
oh yes so i did my bad must have had a blonde moment apolagies for that matey ;D ;D
  • Validating Members
« Reply #64 on: November 06, 2010, 11:03:24 pm »
oh i forgot to ask how would an uprated map sensor help my g40 my polo boots just over a bar of boost if you need to know that
If it's only just over a bar I'd stick with the stock MAP sensor.
You using standard head, cam, bottom end and intercooler?
Offline matthg40
« Reply #65 on: November 07, 2010, 09:49:21 pm »
im using my standard head and cam i only gained the extra boost due to my toothed belt and pulleys ill stick with the standard map sensor im just rather keen to remap my polo so if someone can get back to me with an answer that would be awsome thanks
Offline langersG40
« Reply #66 on: November 14, 2010, 08:59:36 pm »
Hi im interested in one of your chips stage 1 what some of gains HP and Torque wise would i get from it??
many thanks
chris
« Reply #67 on: November 15, 2010, 07:08:48 pm »
We charge £300 for a G40 remap which takes a day with you driving and me mapping. Email enquiries@PoloPerformanceParts.co.uk if you're interested.
many thanks
chris
What's your current spec? We do chips to give safe fuelling and ignition timing for a certain spec - or full remaps to wring every last bit of power from your engine. Power gains will vary depending on your specification and what chip you're currently running.
« Last Edit: November 15, 2010, 07:11:41 pm by Andy »
Offline langersG40
« Reply #68 on: November 15, 2010, 09:22:59 pm »
at the moment its got the standard chip, and pulley, want to put 65mm pulley on with your chip and get my injectors cleaned by you to, just wanted to gain a bit more power than standard, what do you think i would get from the above too? ball park wise? sorry for this question new to G40 ownership byw :D
thanks in advance
chris
Offline matthg40
« Reply #69 on: November 16, 2010, 06:24:16 pm »
my spec on my polo is as follows
jabba sport r1 supercharger
g60 injectors
bored out ported and polished de-wedged throttle body
toothed belts and pullys running a 60mm pully
powerflow stainless exaust system from cat back with cat removed
so i would like to know which ecu chip would be best suited to my car many thanks matt
Offline xandyx
« Reply #70 on: March 16, 2011, 01:13:11 am »
can you please tell me whats the rev limit of #G40001?
i want to go from totally stock to a 65mm pulley and i'd like a chip to match! i have in the shelf a sns nolag but i think it's too agressive for such mod.
greetings
André
« Reply #71 on: March 25, 2011, 06:42:20 pm »
xandyx - Rev limit is 6600rpm, but can be changed to whatever you like.
matthg40 - G40003 is best for your spec. Do you really have a 60mm pulley? 65mm is normally the smallest size used.
« Reply #72 on: March 25, 2011, 06:43:24 pm »
Any new enquiries, please email our chips address:
chips@poloperformanceparts.co.uk
Offline vwmk3jon
« Reply #73 on: April 01, 2011, 01:04:51 pm »
Can i order a chip please? (G400009)
« Reply #74 on: April 03, 2011, 07:09:50 pm »
Email the above address and we'll sort it. A full engine spec list is also helpful in your email, we have several 'flavours' of each chip so try to give you the most appropriate setup for your mods.
