Author Topic: What oil do I put in a stand alone oil tank for my supercharger  (Read 4586 times)
Offline timmyb
Not sure what oil to out in it and how fast should the oil be flowing?
Offline Jezza-7
Re: What oil do I put in a stand alone oil tank for my supercharger
« Reply #1 on: May 19, 2015, 06:55:45 pm »
Im running motocross fork oil. Its expensive but works really well and its the best i have had. Been trying to use all sorts but this has worked the best for me. Its about £22 for a litre or 500ml but i only needed 1 can to fill it up. Been in the tank for over 1 year as well and still is very clean and doing its job. I'll try find the one I'm using.
Offline timmyb
« Reply #2 on: May 19, 2015, 08:56:18 pm »
Brilliant will normal motorbike fork from Halfords do?
Offline timmyb
« Reply #3 on: May 19, 2015, 08:58:35 pm »
I have just put a new facet pump on is this a good move?
« Reply #4 on: May 20, 2015, 04:28:49 pm »
you just want to make sure it's as thin as possible when using a Facet fuel pump.  I used to use compressor oil in mine.
Offline timmyb
« Reply #5 on: May 22, 2015, 02:40:15 pm »
Okay thanks I'll give that a go
Offline Jezza-7
« Reply #6 on: May 26, 2015, 06:48:13 pm »
a new pump is always worth it.
i used the compressor one but the moto x stuff is a little thiner and has better cooling and lubricating properties.
