Author Topic: alternator  (Read 2912 times)
Offline g40jr
alternator
« on: February 03, 2015, 06:25:51 pm »
Is there any other alternators that will fit my g40 mine is completely shot  and need get var up and running again.  Will 6n polo ones work? As I know they are higher amps
Many thanks Jim
Offline kwijibo_coupe
Re: alternator
« Reply #1 on: February 04, 2015, 12:27:52 am »
I have modified a 6n one to fit before.
They have 4 lugs that hold them onto the 6n motor, the bottom right lug needs to be cut off in order to sit right. And also the standard bottom alternator bracket needs another hole drilled just before the bracket bends.
The top two lugs, with a bit of persuading with a hammer, will fit in the mount and I put a bolt through each lug.
So in the end it is held on with 3 bolts instead of the original 2.
I used this setup for a good few months with a standard twin V-Belts and everything seemed to line up ok and it worked fine.
Offline g40jr
Re: alternator
« Reply #2 on: February 04, 2015, 12:41:08 am »
Nice one kwijibo :) I shall get onto buying one
