Oh cock! Melted a plug!
Started by Robin, December 29, 2008, 03:22:43 PM
Robin
this engine has never melted a piston andy.
Andy
Ah, just assumed that it'd been 1341'd because of a meltage...
Robin
nah it was 1341'd because the guy who bought it off me wanted to rebuild it and thought he might as well go 1341cc....................got all the receipts for it and totals over 1k!
Robin
Right final conlusion on why this happened.
After spending some proper time looking at the head and taking the valves out it occured to me that cylinder one spark plug has been helicoiled in a previous life and it looks like the wankers who did it had drilled right through the sodding face of the head!
They basically got a massive fuck off drill and smashed it all the way through cutting into the seat for the inlet valve and also weakening the exhaust valve seat!
I think pics will do the talking! (Ignore the marks on the Cyl 1 face - head got caught on the boot catch when i chucked it in there)
Pikey mo fo's!
Andy
Kind of explains a lot! Probably is also the reason that no.1 plug didn't look normal prior to all this happening - guess it wasn't making particularly good compression in that cylinder?
Anyway, it's great that you've found the cause - at least it can go back together now without worrying that it could happen again.
Robin
Bit of an update, had the valve looked at under a microscope and it looks like it has melted due to exhaust gaes passing past the seat and the valve, the valve seat surface is pretty minging on whats left of it.
Hopefully this will bw sorted out on my next head as i am currently in the middle of lapping them in.
giorgio
Gutted but like Andy says at least its a relatively easy/simple fix.
Whilst your here robin - you got any more pics of your rad set up. You have inspired me
Dan
You can see there that the plug would have sat further away than it should be, due the thread insert. It also looks at the wrong angle too. This will have an adverse affect as the flame would have taken longer to travel and have had a more shrouded path, possibly leading to localised heat affecting the exhaust valve there.
