Hi Tav.
I can see now where I have gone wrong.
My G is still in bits but as far as I'm aware will have the same size connectors of course.
The pump I bought from someone on here has a different socket to my Genisis.
I bought it because I converted the single point injection on the AAV engine code Genisis to mpi NZ with a GT camshaft.
So thought I better upgrade the fuel pump as well but because of that I never have. It does however seem to be unaffected.
Now I know I could just make a set of fly leads to convert the connections Which is probably best unless I can find the proper female plug somewhere off a scrapper.
I'm told that on later models that they made the blades smaller though they look the same to me but the plug is different.
It could just be normal polo's and maybe the G's are all the same. I don't know.
The loom plug on my Genisis wouldn't fit even if the blades were the same because the guides that make sure it connects properly are different as well. Arse!
Pics below.
1st pic shows pump I bought which has the guides on the outer edge of the socket and one center on the other side.
2nd Pic shows the pump on my Genisis and the two guides are closer to the center and none on the other.
3rd pic show the loom plug on my Genisis so you can see why they are different.
Hope this all works Tav. Its been a while since I've done this.
I'll paypal you £50 for a new pump and postage anyhow for the G40. I also have a full GT Engine and setup now to go in the Genisis at somepoint which is chipped in the ecu so I'm sure it'll require the proper pump.
You may know all this already Tav but thought I'd better explain incase its all news to you too.
Thanks for your time Tav. I must meet you one day. The Garage I'm building in my garden is near completion so the G work will start then and hopefully I can start going to all the meets that I have missed out on for one reason or another.
Fred.
