About time I updated this a bit...
Spec was:
- K04
- BVH
- 250kPa MAP sensor
- 77mm Forged Wossners
- Ported GT inlet manifold
- 51mm TB
- EV6 315cc Injectors etc.
First off, the mapping was a nightmare. The mapper didn't have an EPROM emulator to start with but the thing is, he didn't need one the last time he mapped the standard engine to 170bhp with 17.5psi on a K03. He couldn't get it to fuel right at all. There just wasn't enough fuel no matter what he did. He said I should just get an adjustable FPR and tune it that way.
So I fitted one and we put it on the hub dyno. Ran the K04 it at 16psi and adjusted the FPR until my a/f gauge showed it having loads of fuel. It made 201bhp and 174lbft in 3rd gear. Couldn't get it to dyno in 4th whether it was his dyno or my Quaife diff??
It was quick, but the dyno graph was crap to be honest. Had flat spots and had nothing after 6000rpm.
The peak boost of the K04 was 4000rpm. So a power band of 4000-6000rpm wasn't that great.
Drove it like that for a while. One problem was, in order to have enough fuel throughout the rev range, it was seriously rich at idle.
When I say it was quick, it was only as quick as it was when I had the standard engine at 170bhp. It was actually much quicker at 170bhp because it would pull past 140mph in no time, whereas this time it struggled to pull 135mph [which took ages compared to 170bhp]. So ££££'s put into it since 170bhp and its slower. Brilliant!
Posted the graph on here, and gathered from everyone who commented, that in order to get more power from the K04, I would need to increase the rev range. To do that safely, I would be better fitting uprated con rods. Wasn't in the mood to start taking a 1500k mile old engine apart to fit con rods. Plus, If I did get more power, I ran the massive risk of wrecking the gearbox. And how much power is too much power. A bad running 201bhp was hard enough to control with a Quaife diff. Had to learn how to drive the Polo all over again. The diff pulls you all over the road if the road surface is bad.
So with all this in mind, I went back to the K03 setup and refitted the standard FPR. Ran 21psi and got a chip from Andy. IT STILL WOULD NOT RUN! Completely lost as to why it wouldn't work.
Lot of back and forth messages with Andy to try to sort it. Cannot thank him enough for that. Top man.
Long story short, in the end he asked me for the part number of the 315cc injectors. He got back to me and said that the EV6 style injectors [the ones I had fitted] have caused problems for him before. They have a wide spray pattern compared to the EV1 style injectors, which have a narrow spray. He reckons what could have been happening was, the EV6 injectors were spraying onto the walls of the inlet manifold, and gushing in rather than spraying into the cylinders in a fine mist [correct me if I'm wrong Andy].
He said change to a set of 315cc orange top EV1 style injectors and sent me the part number. So I did, and the car ran perfectly!
This I a lot of writing and its not even half of the problems. I tried to shorten it. Was with my mapper on 3 separate occasions for example. I've been trying to sort this car for about 6 months. Finally, things are looking up.
I am now at the stage where I can hopefully get it mapped.
Adrian
