saf's 2014 firesale
Started by grungeisdead, February 10, 2014, 10:50:15 AM
grungeisdead
#30
Still here dude,
I think its actually a 252/276 cam not 272 (that was the piper one)
http://www.bar-tek-tuning.com/SCHRICK+Nockenwelle+g40+86c+polo.htm
From the site
Polo G-40 252°/276° asymetric.
Increasing torque and horsepower! suitable for 170 HP
252°/276°
cam lift 9,6/10,0,
valve lift at TDC 0,7/1,3,
for hydr. lifters
No idea on suitability, although people have put G60 chargers on G40's the idea hasn't appealed to me! I'm sure theres a couple of build threads on conversions here, maybe have a read and see what they used.
Not sure if PPP have had any '60 powered '40s in to map yet?
z3i
Ok mate, have to look into it, yeah there's not a great deal of info on it, seems to be more common with the Germans and Dutch
Can't really find anything over here, search bar isnt very good, neither is Google, just comes up with g60 stuff
No ppp don't, would have to get it trailered to them and custom mapped
How come it hasn't appealed to you?
Ah ok mate thanks
Wouldn't need to trailer it Taylor, could adjust the boost return so it's always slightly open and limits boost to <1 bar and then drive on your G40 map. You'd need a bigger map sensor too of course!
grungeisdead
Cheers Andy.
i sold my 250kpa map sensor fitted ecu to adzcm i think.
I've never considered it because the turbo route is easy, and sounds mint. If I was to supercharge, id go Eaton cheap to replace and should last for ages. Replacing with a charger as expensive as a g40 charger, isn't worth the expense if its as fragile or more so than a 40 lader.
plus 170bhp is faaaaaaar more than enough for everyday driving and hooning and I never damaged any clutches, cv's or driveshafts.
z3i
Ah sweet! Nice idea Andy :)
Yeah I thought about Eaton, but they rob so much power from the crank and I've yet to see one produce more than 220bhp
Turbo is good and is reliable/readily available parts makes it easy plus loads of info. But it's just a bit boring... There is nothing sweeter than toothies screaming through a tunnel!
I thought about lysholm, but £1500 for one.. Forget it
So g60 seems like a good option :) it does worry me with reliability, but I will service it quite often, and I plan on fitting a golf box like Pete, I want that brutal low down cv destroying torque :D
physicsfool
Maybe a silly question but is the volvo steering rack compatible with the G?
grungeisdead
No sorry chap, it looked very very similar to a mk1 golf steering rack (and was sold as such) but upon removing my old one, I realised it wasn't (much to my annoyance!) and was actually stamped volvo on it!
Gayorzzzzzzz
grungeisdead
sorry to all those waiting on parts, everything is being stripped this week, and parts will be out before the end of the week.
Many thanks
grungeisdead
oil cooler was posted for Dave (1982mk1) and he has got it now
banded steelies, helix paddle and g60 injectors gone off to AdzCM and arrived safe and sound.
I have taken a deposit for the PSD exhaust and KW springs. The buyer has a week to get back to me otherwise his deposit will be lost and the parts will be readvertised.
Matt70
grungeisdead
currently spoken for if they get removed from the car, currently had alot of messers with parts off the golf, so its currently not been stripped down yet
Snave
The compo's are just sex  ::)
grungeisdead
still got loads here - having a bit more of a clearout, other bits for sale after a change of heart on a few of the cars. Turned old before my time and bought a bavarian barge
