G40 fuel pump relay
Started by gaz g40, February 05, 2014, 09:05:37 AM
gaz g40
Some how mine is cream crackered so i need to source one of these as theres nothing going to the fuel pump and i cant here the relay when turning the key to ignition. Long shot but has anyone got one?
Is it the fuel pump relay or actually the ecu relay? Had a few ecu ones go but not fuel
randombadger69
Which one powers up first? Ecu or fuel pump? Power is piggy back so to speak on these iirc? Had a problem with one myself recently. I think it was a case of Ecu relay faulty stopping the fuel pump priming.
Answered my own question there I guess!
gaz g40
Which one is the for pin relay? As ive swapped that one with another one an still no luck. So im guessing i need the five pin
4 pin is fuel pump, 5 pin is ecu.
If you want to borrow a 5 pin i can dig one out mate?
Etches
This happened to mine gaz, any 5 pin relay will worth. Think my mate robbed one from a xara or something. Mine had melted!
gaz g40
Pete that would be awesome if you dont mind? I just want her to run so i get motivated
