Trials and tribulations of a cheap G40
Started by physicsfool, December 22, 2013, 03:36:29 PM
z3i
Haha :P
I found a website that sells near identical rubber things for cheap
I'll post it up later
physicsfool
#31
Taylor pointed me in the direction Bigg Red a brake refurbishment company! So decided the brakes needed stripping and prepping as they have a lot of surface rust!
http://
Talk to me.... ive got some calipers fresh refurbished but one has an issue... at very least they can be used for new pistons,  piston seals, nipples etc!
z3i
Nipped ha
Martin stripping his calipers down at 1 in the morning :P
physicsfool
Gotta squeeze every hour out of the day! Especially when the missus isn't round!
physicsfool
Righto, been about a month since my last update... So here is my process so far, this is the slower slightly less revolutionary stuff, but a big ol' learning curve never the less.
here are the areas of greatest concern.. drivers side sill
coil pack area
and bottom of the passenger side front wheel arch corner
First bit of fabrication
And the rear wheel arches are in decent condition, nothing a quick sand and primer won't sort
Arches are fully stripped and welded up, welds are still looking urrrrgggeeellly but doing the trick
Annd the drivers side with the rust patches brushed out and etch primered up
Empty bay with small weld job by the coil pack area
brakes and steering arms are close to being refurbed so not long till she is rolling once again....
z3i
Ahh! Yes!! She is bare indeed! Love it dude! She is going to look epic once painted ;)
physicsfool
So update, most of this was on a thread but trying to keep it sequential
Found the drivers side chassis leg is cracked and slightly off, so i need to get hold of a stage 2 subframe from PPP and get it welded up, not ideal but it will be worth it when its finished.
from the underside, its cracked the underseal which isnt ideal
and separated slightly
this also looks fairly lairy but i was calmed by the other G40 chaps and with it due a respray in the next month its going to look quality when all put back together
I have also sent the rear axle off for sandblasting as its looks pretty rusty.
Picking up the painted front struts with fresh skf bearings thanks to Taylor and all parts to refurb the rear drums inc cables and bearings (PeteG40).
Will be at Stanford hall this weekend so good motivation to get the polo finished
physicsfool
Here are some photos of the front struts being painted and other bits and bobs
Here is how the strut started out
Once sandblasted and painted (z3i or Taylor)
Painted disc protectors, fairly pitted but Taylor has done a cracking job
bearings pressed in and looking goood. Thanks again Taylor top lad
Steering arms also needed a refresh
and paint
I have painted them black since, just don't have a photo of it
any way I think that's pretty much it so far..
randombadger69
Some top work going on here!
Keep it up!
Quote from: z3i on February 20, 2014, 10:14:26 AM
Haha :P
GSF list the Fuel pump bracket rubbers for fairly cheap under "injection parts" iirc.
physicsfool
Afternoon all, mid week boredom has kicked in so updating this with last weekends work!
First things first (rear axle bushes going in) questionable choice in footwear i agree and the track suit trousers shouldnt really be worn in public but fashion isnt a priority anymore, getting this car finished is.
This is where the weekend started, no wheels and no engine
Coming together with the GAZ rear coilovers i purchsed off Matty! cheers lad
All in place ready for the wheel
And finally she is rolling again (sort of)
Fitted an uprated radiator brace in prep for the PPP stage 2 subframe and welding that will happen soon
Sun is shining all is coming along well so i decide to take another look at the drivers side sill which isnt looking too great
Its fairly rotten all the way along, so currently assessing my options.
z3i
You make that brace yourself? Nice idea!!
Rear axle looks so clean man! Nice work!!
physicsfool
Got the uprated rad brace off vee_dub90, mild steel and zinc coated! quite the weapon. twinned with a stage 2 she will be a handling monster
z3i
And modified chassis! And Gaz coilies! Oh and weight saving from all those rust holes :P
You decided on front shocks yet?
