powerful G
Started by samuel.cole, October 03, 2013, 12:45:57 PM
samuel.cole
Right ive decided to keep my charger set up and build some crazy ass G40 with some money i have been saving,
got a fair bit to spend, but not sure whats best for what power gains. im looking to get the most out of my charger as i know its not running at its full potential at the moment. looking at cams, exhaust, pistons, conrods, chip tune, head work the lot, want as much power as i can get afford ably.
suggestions and ideas are all welcome, im not sure what or where to get it!
thanks
Sam
z3i
Ppp main and system (polo performance Parts)
Big valve head  + flowing (man in the shed) don't go to Jabba sport
1341cc bottom end, one for sale on here
Charger porting. (only charged dubs) again Jabb. Are shite
Cams (shrick are rated highly. Find a dealer)
Qauife diff (tsr tuning)
G60 injectors (eBay)
gT inlet
51mm throttle body Justin on here
Ppp for a custom map
Pete g40 is selling an aqua mist kit (devils own)
z3i
You won't need rods if your staying g40, not enough boost. But you can get PEC ones from the bay at good prices
Etches
Quote from: z3i on October 03, 2013, 01:20:04 PM
Ppp main and system (polo performance Parts) £900?
Big valve head  + flowing (man in the shed) don't go to Jabba sport  £500
1341cc bottom end, one for sale on here £1000 if done by yourself inc bolt for bolt rebuild
Charger porting. (only charged dubs) again Jabb. £200- 400
Cams (shrick are rated highly. Find a dealer) £170 Newman £180+ shrick
Qauife diff (tsr tuning) £750?
G60 injectors (eBay) £50- £80
gT inlet £20-40
51mm throttle body Justin on here £100- £120
Ppp for a custom map £80 off the shelf , £400 for a live one with set up
Pete g40 is selling an aqua mist kit (devils own) can be up to £300
4.5k plus for that lot  ;D
you'll end up with about 180 or so bhp, it's been done.  Just go turbo :D
samuel.cole
i wanna stay with the lysholm and get it silly quick, what would you say from the list will add most power?
oh you've got a lysholm charger?  I thought you meant the g-lader.
if you want to make the car quicker then a differential will be the most effective one on that list.
as for power it's a bit hard to say as we dont know what state the car is currently in.  If it's never had a proper remap then that'd be worthwhile.
Matty!
OCD are excellent customer service has been great for me so far!
Interested in seeing what your car will gain, as if this G lader goes again I think im going to go Lysholm crazy build too! Bet it sounds nuts!
z3i
Jabba are good at porting, pretty poor at rebuilding
scotsjohn
Before you've nailed down the engine mods., you might be advised to think about uprating the drivetrain. Half-shafts, clutch, a pail of C.V. joints and the odd spare ATV box. Power isn't cheap in your G.
OCDmatt
Hi, thanks Matty, that's great to hear!
Jezza, can I ask why? I might be able to clear things up for you there :)
samuel.cole
Errmmmmm one question, can i change the pulley for the lysholm (to wind it up a bit) ??!
OCDmatt
yes you can, BBM do a 53mm pulley for 18+psi
samuel.cole
can i run toothed belts on the lysholm? also where would i find spare belts/ new belts as iw ould like to replace mine!
samuel.cole
would a forged bottom end (wossener pistons and forged conrods etc) help, i know it would be stronger and allow me to run more boost, but straight off would it give any more power?
thanks
