Author Topic: I've written my G off! :(  (Read 4780 times)
Offline Lewis
« on: July 13, 2013, 11:19:53 am »
So,
the one time I'm driving sensibly, I wasn't speeding, I wasn't doing anything I shouldn't be, a bell end in a 11 plate E92 BMW pulls out on me leaving me with this....
I'm genuinely gutted! I just hope it an be revived!
Mechanically it's sound, I just hope it's only panel damage an the chassis legs aren't damaged.
Re: I've written my G off! :(
« Reply #1 on: July 13, 2013, 02:41:20 pm »
Check tcas and chassis legs. Id be surprised if it was just panel damage.   Bummer tho
Offline Lewis
« Reply #2 on: July 13, 2013, 02:53:50 pm »
The chassis leg is bent unfortunately :(
PeteG40,
I bought it from a guy in Barnsley and he said you serviced the charger on it (H757 WNP)
What sort of condition is it in?
Ta
Offline z3i
« Reply #3 on: July 13, 2013, 03:17:18 pm »
Shes repairable :) weve repaired much worse at work!
You can always re shell it? :) all is not lost
sucks though
« Reply #4 on: July 13, 2013, 03:43:06 pm »
I also did cambelt plugs new rocker gasket too.  Charger I think seemed good stage4 iirc
Offline gaz g40
« Reply #5 on: July 13, 2013, 08:47:23 pm »
Bummer man. You baught it off of someone called chris then? Paintwork was lovely aswell :(
« Reply #6 on: July 13, 2013, 09:37:58 pm »
Gutted for you mate, looks like a clean g. Hopefully it can be fixed. Check for cracks at the bulkhead end of the chassis legs.
Offline z3i
« Reply #7 on: July 13, 2013, 10:22:21 pm »
invest in a stage 2 subframe and bolt it up too the chassis legs, you can see if theyve moved then
« Reply #8 on: July 14, 2013, 01:41:13 am »
Already got a stage 2
Offline dan1300r
« Reply #9 on: July 14, 2013, 02:38:01 pm »
My G40 didn't end up going to the scrapyard yesterday as I went away. I have all the bits you need to fix this (In Red).
Offline z3i
« Reply #10 on: July 14, 2013, 03:34:38 pm »
Do you think having a stage 2 may have saved the chassis legs? or helped them not crumple so much?
Offline sleag40
  • Poloist
« Reply #11 on: July 14, 2013, 05:52:01 pm »
When mine was crashed last year the car bent around the frame damaging the A pillar. If theres no damage as far back as that it can probably be jigged. Proper bogus though chief.  Don't let insurance company take the piss!
