[quote pid=46 author=Beavis date=1204486757]Depending upon if it is old/new stock at your local GSF you may have to ask for a set of 'WR5DP0', same plug but have a Resistor in them, same money, but later stocks are WR's as they may tell you that W5's are a obsolete line.[/quote]
ok thanks for that.. im convinced my plugs are the reason for my slight early morning misfire. on start up on the cold mornings the car seems to be running on 3 cylinders, literally for the first half a minute if that until ive pulled out my space in the street. the car runs absolutly fine, drives perfect but this has been something that has bugged me over the last few months and im convinced its the plugs. 30 odd k on plugs is quite a length of time so its possible one or all of them have seen better days i would have thought. everything else is new as most of you will know so im gonna try plugs and see if it solves it. its literally just on these colder mornings and doesnt have idle issues or running problems any further than this startup issue.
