timing side g lader casing
Started by z3i, April 29, 2013, 11:52:51 AM
z3i
In need of the timing side casing
Preferably r1 spec or Psd full blend with no damage but standard porting will do
fitting new seals and bearings so not worried if it hasnt been serviced
not too worries if the casing is a little worn as i will be using black seal strips
many thanks
Poloace
Are you still interested, I have a charger in bits which has a good inlet and outlet but the scroll is damaged.
z3i
Quote from: Poloace on May 23, 2013, 09:48:49 PM
Sorry mate, completely forgot about this, i managed to get an r1 charger
thanks though :)
