Control arms
Started by physicsfool, May 10, 2013, 04:22:01 PM
physicsfool
Looking for control arms, fella at allgermanparts wasn't convinced the standard arm for a 90-94 polo was the same as for a G40.
Any tips on where might stock them, and if it will be compatible for a g40?
Standard polo arms fit but a very poor choice. Original arms are obsolete? Look at PPP site on here for what you really need.
NeilG40
PPP aren't recommended for road use.
JoeH
I'm actually in the process of buying the Febi-bilstein TCA (for non G40) from allgermanparts as you say, then Glader nylons on the outer, and powerflex on the inner. I don't know, but I see now reason why this won't be as good, if not better than standard G40 TCA, which are probably quite worn by now...
GLaderseite do sell some G40 rosejointed TCA's
GeirJB
Etches
Thats not got the rose joint?
GeirJB
It says for G40, so I hope they are rose-jointed.. Because i did order a pair of them!
z3i
Quote from: Jezza-7 on May 14, 2013, 11:17:01 PM
Them front g40 badges are cheap
http://www.etkashop.com/vwcp/Polo-Derby/Polo-II-2F/Karosserie/Aussen/Schriftzug-G40.html
Went to buy one as i thought the same, but postage is 30 euros or something insane
GeirJB
