running issues
Started by langersG40, January 25, 2012, 08:52:50 PM
langersG40
right i seem to have an intermitent running issue, drive beautiful most of the time, but like this evening it runs very lumpy, hunting, bit hesitant,
any help id be most gratful
ttfn
chris
whats it like when its warm?
langersG40
the same, like i said tomoorw jezza, il run fine, where as today from cold to getting home ran like a bag of shit >:(
Could be something like coil or dizzy. Whats the condition of your dizzy? Is the hall sender ok?
langersG40
oh really oh bugger, how do i check hall sender??? the dizzy cap and rotor arm were replaced last year
Usually best way for the hall sender is if it the plastic part is cracked or loose. I had a problem once where it ran ruff but only after a while and this was caused from hall sender. If it was the hall sender your engine would most likely cut out.
What about plugs and leads?
langersG40
leads replaced again about a yr ago, but will do plugs next em thinks ahhhh my hall sender plastic part is cracked and loose will give that a go first!!! cheers mate
Yeah when they are loose the tend to wiggle the wires inside and they are soo small it doesn't take much to break them. It sometimes doesnt completely stop the car from running but it will run ruff. Mine ran ruff then cut out on me twice then ran ok for a month.
if the coil is old - replace that for the price they are and for piece of mind!
