Crownwheel and pinion
Started by josh_terry_pro2, August 18, 2011, 11:21:25 AM
josh_terry_pro2
Hi guys im after a diff, including the crownwheel and pinion specifically from a g40 box as im building a super low ratio 8p box. The part number for the crownwheel and pinion set is 085409143f the gears are 60/18 teeth. pm or txt me on 07800979855. no scammers or bullshitters as i can spot you a mile off! :P
