Lamba Probe
Started by LeonL, October 13, 2009, 08:12:21 AM
LeonL
Hi,
Need to purchase a new one of these as it appears to be the problem to my hunting revs!
On eurocarparts they have a few different Bosch ones around the £70-80 mark, with different sizes. Any one know why?
Can anyone point me in the direction of the correct one for my car? (L,1994 Polo G40)
Leon
Justin14100
There is the correct on on eBay, there are loads on there for the MK3's and most of them are the same, I think if you search 1.3g40 with no spaces like that you can find the right one, v1 is the on you need - or search 'PY LAMBDA' should come to the same result they are all Bosch ones for about £50 I think!
LeonL
Quailty...Thanks for that, appricated :)
How do you know its V1 i need and not V2?
jscmk3
Justin14100
V2 is the non cat one, I asked on here before aparenty the only difference is the cable length, the v1 says it lasts longer too - read the description "; get the one that has the shorter cable lenght and lasts longer
quiksilver_jake
Ebay .. I got my propper bosch one off there £50 ish spot on as well !
cheys03
www.justlambda.co.uk for genuine Bosch ones also, under £60.
dekerf1996
Sorry for dragging up an old post, had a look at this post, but still not sure which lambda probe to buy.
ECP list 4
http://www.eurocarparts.com/lambda-sensor
Think its the one in stock at just under £80.
Now had a look on ebay and can get it about £5 cheaper, so would rather go through ECP unless really much cheaper....
