6n metal head gasket or standard g40 one
Started by Jezza-7, June 02, 2011, 05:44:39 PM
As above really. Whats the difference and what should i go with?
Head has been skimmed and the bottom end looks level. Have checked it out with a straight edge.
jez1272gt
a metal one is thinner therefor increasing your CR. as you have had the head skimmed i would go with a standard one. will be good for all but the highest power G's...
well I would say with a standard CR bottom end, go for the thinner one.  Assuming the car is in good order a slight increase in CR is only a good thing
Ok then i will stick the metal one on.
stuG40
I'm going for the metal one aswell, but my block is bored out to 77mm, and the metal head gasket is 76.5mm is this still ok to use???
cheers..
the metal one is still ok to use, just.  plenty of 1341cc polos use them
