Author Topic: steering wheel shakes under moderate to heavy braking  (Read 3364 times)
Offline JIMMYP
« on: July 18, 2010, 03:12:24 pm »
ive put some ebc front pads and discs on my g40. but under moderate to heavy braking the steering wheel shakes. does anybody have any thoughts?
Offline breadman
Re: steering wheel shakes under moderate to heavy braking
« Reply #1 on: July 18, 2010, 08:46:35 pm »
Did you ensure the mating face of the hubs were completely clean and free from bruises and burrs? If not the discs won't run completely true and this can lead to the problem you have.
Offline gti jack
« Reply #2 on: July 18, 2010, 08:46:50 pm »
warped disc maybe?
im no expert but it happend on my gti polo and it was because of a warped disc, im sure someone on here will give you a deffo answere tho!
Offline JIMMYP
« Reply #3 on: July 19, 2010, 07:39:10 pm »
i dti the drive flanges today and they are running true cant c no issues with them. i might put old discs on and c if that cures the problem. cus it will b difficult to dti my ebc discs cus there grooved and dimpled.
Offline mstar
« Reply #4 on: August 10, 2010, 09:46:46 pm »
I have the same, EBC dimpled disc's and red stuff pads. but have to admit I had major issues to fit in two new rubber bushes with the nylon/tefon inner bushing. What ever I tried I could not make it slight smooth. So put the old back in  :(
Offline G40supercharged
« Reply #5 on: August 10, 2010, 10:46:04 pm »
Worn anti roll bar mounting bushes will make the steering judder under braking. When I had this problem I found it didn't judder every time. I used powerflex anti roll bar bushes to sort the problem. If the disks are warped you would probably feel it through the pedal.
Offline JIMMYP
« Reply #6 on: August 12, 2010, 01:41:14 pm »
ive powerflexed the anti roll bars on the arm ends and the mounting bushes. it has improved it but still shakes only happens when the brakes warm up more visiously so im putting it down to the brakes have quite a bit of bite to them. its dont vier off or anything underheavy braking it just shakes so i can live with it.
Offline polo classic
« Reply #7 on: August 12, 2010, 02:02:08 pm »
EBC discs are crap and will warp
Offline Puncharado
« Reply #8 on: August 12, 2010, 05:52:43 pm »
EBC discs don't warp, they develop thin spots due to run out. :D :D
http://www.polog40.co.uk/forum/index.php/topic,5100.0.html
Offline Jezza-7
« Reply #9 on: August 29, 2010, 10:23:19 pm »
I have the same problem with the vibrating and i think its down to the pads. I have red stuff pads. I think im gonna get rid of them and try something else.
