Help with fueling parts etc
Started by Jezza-7, December 09, 2009, 05:47:00 PM
Im looking at replacing a few parts in the fuel line/system but im not sure excactly what i need and not to do.
Im looking at 3 things at the moment,
pre feed intank fuel pump
inline filter
injection fuel pump
but im not sure if things are the same or what.
Here are the links to waht im looking at and if someone could point me in the right direction or even tell me more about what i need to do in the fuel line it would be great.
http://www.merlinmotorsport.co.uk/p13253/Fuel-Pump-VOLKSWAGEN-Polo-Coupe-1.3i-G40-%28Pre-feede-%2835790609C%29/product_info.html
http://www.merlinmotorsport.co.uk/p1944/INJECTION-FILTER-8MM-X-8MM/product_info.html
http://www.merlinmotorsport.co.uk/p1997/FACET-COMPETITION-INJECTION-FUEL-PUMP--6-OR--8-JIC-IN/OUT/product_info.html
unless you are going ultra crazy
oem spec should be fine.  Hayeseys 190+bhp uses oem (new ones mind)
So really what i put up isnt essential.
Unless as you said going crazy.
Is it worth even getting the fuel filter or still stick with oem one? Like the hengst ones from euro car parts?
use OEM for all of it.  No need to use a higher flowing fuel pump unless you are planning on much over 200bhp.
Henry
I've got a brand new vag lift pump for sale, drop me a pm if you want it
