New water pump and cam belt £20
Started by PeteG40, November 25, 2009, 09:16:49 AM
its a QS water pump, new unused boxed for round tooth (91-94) polo, includes seal.  Metal impeller and is decent enough quality.
Gates timing belt, new unused also.
£20 the pair + p+p
perfect for whoever buys my head or bottom end!
should be - 99% of g40s have round toothed cambelts and water pumps - i can check with your engine number if you want
yeah ok, is that the really long number?
something like wwvw?
Deleted
not good for cloners!
PY xxxxxx is engine number
 :o Oh i see.
Where will i find that? Is it on the little metal plate on the left hand side of the engine bay, above the headlight?
Yeah thought so. Im away from home till next saturday so wont be able to get it till then. Will see if i can get it from car.
Mine is a late (sept) 1992. Does that make it a MK2FG40?
MartinB
Basically all UK G40's are MK2f's...
