near side adjustable steering arm??
Started by jez1272gt, November 04, 2009, 05:08:12 PM
yeah the arms on the gaz coilovers are considerably lower than on standard struts, probably a good two inches lower from looking at pictures.
jez1272gt
Correct the arms are lower on the Gaz units than on the standard strut. I meant that the arms are loacted in the same place 'around' the strut body rather than vertically up it!
jez1272gt
Do you ever get the feeling you are being a comeplete and utter twat? I sure feel like im being one at the moment  :D
Can someone please tell me the measurement of the offside (non adjusatble) steering arm? Mine appears to be 550mm from centre of the bolt hole to the centre of the ball joint thread....
... i have a funny feeling someone is going to tell me that this too long and that im an idiot!!!!
Weeman
My none adjustable arm is around 515mm long
seems that yours is way long and causing your problem.
jez1272gt
Thanks Weeman. Appreciated
What a f'ing tool i am!!  ::)
I even looked at the problem initially and told myself that the offside arm would be at fault then i somehow ruled that out and went off chasing shadows. DICK
Moral of this story - im an idiot!!  :o
Weeman
no worries!
So whats your steering arm come from?
jez1272gt
God only knows - i got it new as a replacement for the shot one when i stripped the car down!!
Time to find another new one then!!!
Don't know if you'll get a proper one for the G now. I had to wait quite a while for mine(both sides) and that was last winter. Interesting to find out what the problem one came from though. Does it have a rose jointed inner bush?. I fitted mine without noticing they were rose jointed and some one else highlighted that they were. As to what's out there, my old G had adjustables both sides which caused a bit of head scratching at the dealers when I tried to renew them, so don't be too hard on yourself.
jez1272gt
The incorrect off-side arm is non adjustable and fixed bush (no rose joint :-[)
Will try and find out what it came from but it was definately for a VW of some descipt...
Genuine off side adjustable arms are no longer available according to my dealer so i guess i'll do GSF or similar for another arm and see what i get.......  :D
jez1272gt
Problem sorted now. Took awhile to find a new arm but got there in the end. Even VW seem to list the mk3 polo off side steering arms as 550mm in length. Very strange!!!! Had to specify that the arm was only 515mm to the manufacturer to get the right one sent out!
