5th gear set, Mk4 16v
Started by Nick_S, November 01, 2009, 06:01:53 PM
Nick_S
I have a 5th gear set for a mk4 16v 085 type gear box, gives a ratio of 0.891:1
Its in really good condition with little signs of wear, comes with the syncro and needle bearing. Ideal if you have a valver with a busted 5th gear, as this lot from VW would set you back in the region of £200 new.
Will fit other 085 boxes too if you want to build a hybrid with this ratio.
£10 plus postage.
