Spark Plugs
Started by Dingle_Polo, September 17, 2009, 07:31:40 PM
Dingle_Polo
I am going to carry out a full service this weekend ready for the winter and wondered what plugs were gd for a modded g40 engine.
advice would be appreciated
thanks zack
Bosch W5DP0 are the ones to use.
Tommo
Or NGK BP7 EVX, which are cheaper and probably superseed the bosch ones.  :P :P :P
Dingle_Polo
ok il give them a go thanks for the info.
cheers zack
grayg40
I wouldnt use the NGK ones. mine melted every time i went above 120. as soon as i put tyhe Bosch ones back in i never had a problem, now i can blast past the 120 mark with no worries
You've got a problem then- try a colder grade. The NGK are by far a harder plug than the Bosch.
Tommo
Yeah, and the Higher the number the colder the plug IIRC, so try 8's. But I dont see a reason why you should have to.
