having some stange problem
Started by chase_g40, July 24, 2009, 07:51:48 PM
chase_g40
hi there im having some strange problem
when i start the car it runs fine
but when i start to drive it, it starts to judder and cuts out, once i start it back up its fine den when im driving at bout 2-3 rpm it starts to judder again but when i put the throttle down it goes away,
but den if i go to put the throttle down it loses all power den out of no where it kicks in again in a burst and does this in all gears no matter what the temp is,
really doing my head in but ive bin told its running really RICH as you smell the petrol fumes badly and can watch the gauge drop
i asked a rac guy he told me it might be the blue temp sensor but wasnt too sure so i fort ide ask people on here
can someone help please ???  :(
Doc J
Can you see your boost and AFR? You can try to disconnect the plug of the blue sensor when the thermostat is opend and if there is no difference in the engine work - the sensor is gone.
DKnight
your car is in limp mode by sounds of it, cutting out because one of the sensors is telling it something
do as said above, let the car get up to temperature, and unplug the blue temp sensor, try it look for change, den do the same with the lambda probe
it has to be one of these causing the problem  ::)
chase_g40
chase_g40
just a update guys and galls it ended up being a vacum hose but i dont seem to to get any vacum pull on the throttle body side that goes to a fuel diaprham cant figure it out ???
