compression on g40
Started by dcc, August 01, 2009, 12:43:26 AM
dcc
What are the compression results that should be expected from a healthy G40 engine, standard bore/stroke. (compression ratio and also a psi reading if possible)
dcc
nobody know what healthy compression test results are on a g40?
Daryl
done my mates the other day. He is popping over in abit i will find out what it was
